Tabulate Stacked Columns List
Shared Item Messages
Add Line Annotation
Syntax: obj << Add Line Annotation
Description: Adds a line on top of the display box.
//This message applies to all display box objects
biv = dt << Bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Add Line Annotation( Line( 160, 235, 240, 235 ) );
Add Pin Annotation
Syntax: obj << Add Pin Annotation
Description: Adds a pinned annotation on top of a display box. Most attributes (such as Index Row, UniqueID and FoundPt) are designed for internal use only.
dt << Bivariate(
    Y( :weight ),
    X( :height ),
    SendToReport(
        Dispatch( {}, "Bivar Plot", FrameBox,
            Add Pin Annotation(
                Seg( Marker Seg( 1 ) ),
                Index( 17 ),
                Index Row( 17 ),
                UniqueID( -960001792 ),
                FoundPt( {238, 219} ),
                Origin( {64.9765625, 142} ),
                Offset( {-174, -40} ),
                Tag Line( 1 ),
                Font( "Helvetica", 11, "Plain" )
Add Polygon Annotation
Syntax: obj << Add Polygon Annotation
Description: Adds a polygon on top of the display box.
rbiv << Add Polygon Annotation(
    Points( {210, 80}, {230, 70}, {280, 115}, {240, 120} ),
    Color( "Red" ),
    Closed( 1 )
Add Simple Shape Annotation
Syntax: obj << Add Simple Shape Annotation
Description: Adds a simple shape on top of the display box.
rbiv << Add Simple Shape Annotation( Oval( 210, 100, 250, 75 ) );
rbiv << Add Simple Shape Annotation( Rectangle( 70, 180, 95, 215 ) );
Add Text Annotation
Syntax: obj << Add Text Annotation
Description: Adds text on top of the display box.
rbiv << Add Text Annotation(
    Text( "We need to discuss this at the next meeting." ),
    Text Box( {65, 35, 200, 77} )
Append
Syntax: obj << Append( db2 )
Description: Add db2 to the display tree after db.
rbiv << append( Text Box( "=== below ===" ) );
Background Color
Syntax: obj << Background Color( color );color = obj << Get Background Color
Description: If the background color is set, the box is filled with the background color prior to drawing its content. If the background color is not set, the background and content of the containing boxes show through.
JMP Version Added: 15
d = dt << Distribution( Column( :height ) );
r = d << report;
tb = r[Table Box( 1 )];
Show( tb << Get Background Color );
Wait( 2 );
tb << Background Color( "Yellow" );
Border
Syntax: obj << Border( sides );sides = obj << Get Border
Description: Borders are solid lines drawn around the outside of a display box. If a single value is provided, it will be applied to all sides. If two values are specified, they will be applied to horizontal and vertical borders.
r = d << report;
Show( tb << Get Border );
Wait( 1 );
tb << Border( 1 );
Border Color
Syntax: obj << Border Color( color );color = obj << Get Border Color
Description: Optional color to override the default color for box borders.
JMP Version Added: 19
r = d << report;
Wait( 2 );
tb << Border( 1 );
tb << Border Color( "Light Red" );
Bring Window To Front
Syntax: obj << Bring Window To Front
Description: Brings the window to the front.
w = Open( "$SAMPLE_DATA/Big Class.jmp" );
w << Run Script( "Bivariate" );
w << Bring Window To Front;
Child
Syntax: obj << Child
Description: Returns the child of the display box.
axisbox = rbiv[axis box( 1 )];
axisParent = axisbox << parent();
axisChild = axisParent << child();
Print( axisChild << Class Name() );
Class Name
Syntax: obj << Class Name
Description: Returns the name of the display class for the display box.
axisbox << Class Name();
Clone Box
Syntax: obj << Clone Box
Description: Makes a new copy of the display box.
clonedBox = rbiv << Clone Box();
rbiv << append( clonedBox );
Close Window
Syntax: obj << Close Window( <"NoSave"> )
Description: Closes the window.
Wait( 2 );
w << Close Window;
Copy Data
Syntax: obj << Copy Data
Description: copies the tab-delimited data from a matrix or table to the clip board.
New Window( "x", mat = Matrix Box( [1 2 3, 4 5 6, 7 8 9] ) );
mat << CopyData;
Copy Graph
Syntax: obj << Copy Graph
Description: Puts a picture of the graph and axes on the clipboard.
(rbiv[FrameBox( 1 )]) << Copy Graph();
"paste into a paint program";
Copy Picture
Syntax: obj << Copy Picture
Description: Puts a picture of the display box on the clipboard.
rbiv << Copy Picture();
Delete Box
Syntax: obj << Delete Box
Description: Delete the display box.
axisbox << Delete Box();
Deselect
Syntax: obj << Deselect
Description: Deselects this object for use by Edit menu commands.
selected = 0;
New Window( "Example",
    ex = Button Box( "Press Me",
        selected = !selected;
        refresh;
refresh = Function( {},
    If( selected,
        ex << Select,
        ex << Deselect
Dispatch
Syntax: obj << Dispatch( {outline node, ...}, display element, display element type, command )
Description: Send command to a specific part of a display tree.
rbiv << Dispatch( {}, "Bivar Plot", FrameBox, {Marker Size( 3 )} );
Enabled
Syntax: obj << Enabled( state=0|1 );state = obj << Get Enabled
Description: An object that is not enabled will not respond to keyboard or mouse input. This property is inherited by child objects, so a container object that is disabled will cause all descendent objects to be disabled.
//This message applies to all display objects
New Window( "enabled",
    V List Box(
        check = Check Box(
            {"Use Password"},
            ptext << Enabled( check << Get( 1 ) );
            pvalue << Enabled( check << Get( 1 ) );
        Lineup Box( N Col( 2 ),
            Text Box( "Username:" ),
            Text Edit Box( "", <<Set Width( 100 ) ),
            ptext = Text Box( "Password:", <<Enabled( 0 ) ),
            pvalue = Text Edit Box( "",
                <<Password Style( 1 ),
                <<Set Width( 20 ),
                <<Enabled( 0 )
Find
Syntax: obj << Find
Description: Returns a display box with the given argument.
axisbox = rbiv << Find( axis box( 1 ) );
axisbox << Delete();
Get Annotation
Syntax: obj << Get Annotation
Description: Returns the first annotation that is anchored to this display box. Other annotations can be accessed by using Sib() on the result.
annotation = rbiv << Get Annotation;
annotation << delete;
r = d << report;
Wait( 2 );
Get Border
r = d << report;
Wait( 1 );
tb << Border( 1 );
Get Border Color
r = d << report;
Wait( 2 );
tb << Border( 1 );
Get Content Size
Syntax: obj << Get Content Size
Description: Returns the content size within the window.
c = w << Get Content Size();
Show( c );
Get Display Path
Syntax: obj << Get Display Path( parent box, <receiver expr>, <Mode("XPath"|"Subscript")> )
Description: Gets a relatively robust expression to navigate between parent box and obj. This path is not guaranteed to be stable across JMP releases. The receiver expr is incorporated into the output expression if provided. If not, the expression provided for parent box is used instead. As shown in the example, this message is mainly useful for increasing the robustness of a path you already have available. The XPath mode is default.
Basic
biv = dt << Run Script( "Bivariate" );
rpt = Report( biv );
xpath expr = rpt[Number Col Box( 9 )] << Get Display Path( rpt, Expr( Report( biv ) ) ); // Make Number Col Box(9) more robust
Show( xpath expr );
xpath expr << Select;
Subscript Mode
subscript expr = rpt[Number Col Box( 9 )] << Get Display Path( rpt, Mode( "Subscript" ) ); // Make Number Col Box(9) more robust
Show( subscript expr );
subscript expr << Select;
Get Enabled
    V List Box(
        check = Check Box(
            {"Use Password"},
                <<Set Width( 20 ),
                <<Enabled( 0 )
Get HTML
Syntax: obj << Get HTML( <format> )
Description: Returns a string containing HTML source for the display box.
Example 1
win = New Window( "Example", a = Text Box( "Example Text" ) );
a << Set Text( win << Get HTML );
Example 2
obj = dt << Oneway( Y( :height ), X( :sex ), Means( 1 ), Mean Diamonds( 1 ) );
Save Text File( "$TEMP/Oneway.html", obj << Get HTML( "svg" ) ); // Prefer <<Save HTML
Web( "$TEMP/Oneway.html", JMPWindow );
Get Height
Syntax: width = obj << Get Height
Description: Returns the height of the display box.
r = d << report;
fb = r[framebox( 1 )];
fb << Get Height;
Get Horizontal Alignment
Syntax: obj << Horizontal Alignment( "Default"|"Left"|"Center"|"Right" );"Default"|"Left"|"Center"|"Right" = obj << Get Horizontal Alignment
Description: Horizontal alignment controls the positioning of the box within a container if the box does not fill the entire space.
r = d << report;
lb = r[List Box( 6 )];
lb << Border( 1 );
Wait( 2 );
lb << Horizontal Alignment( "Right" );
Get Journal
Syntax: obj << Get Journal
Description: Returns a string containing journal source for the display box.
Print( rbiv << Get Journal );
Get Margin
Syntax: obj << Margin( sides );sides = obj << Get Margin
Description: Margin adds space between the border of the box and adjacent boxes. Use named arguments, or provide a list of values. If a single value is provided, it will be applied to all sides. If two values are specified, they will be applied to horizontal and vertical margins.
r = d << report;
Show( tb << Get Margin );
tb << Border( 1 );
Wait( 2 );
tb << Margin( Left( 20 ), Top( 20 ), Right( 20 ), Bottom( 20 ) );
Get Max Size
Syntax: width,height = obj << Get Max Size
Description: Returns the maximum size of this display box for purposes of auto-stretching.
dt = Open( "$SAMPLE_DATA/big class.jmp" );
r = d << report;
fb << Get Max Size;
Get Min Size
Syntax: width,height = obj << Get Min Size
Description: Returns the minimum size of this display box for purposes of auto-stretching.
r = d << report;
fb << Get Min Size;
Get Namespace
Syntax: obj << Get Namespace
Description: Returns the namespace associated with this display object.
x = 1;
w = New Window( "Test", b = Button Box( "Press me" ) );
b:x = 2;
ns = b << GetNamespace();
Show( ns:x, x );
Get On Close
Syntax: obj << Get On Close
Description: Returns the script or function that will run when the window closes.
w << On Close(
    // Modal dialogs return Button(1) if OK is pressed, Button(-1) if canceled
    New Window( "Are you sure?",
        <<modal,
        V List Box(
            Text Box( "Press OK to allow the window to close" ),
            H List Box( Button Box( "OK" ), Button Box( "Cancel" ) )
    )["button"] == 1
Show( w << Get On Close );
Get Padding
Syntax: obj << Padding( sides );sides = obj << Get Padding
Description: Padding adds space between the content and the border of the box. Use named arguments, or provide a list of values. If a single value is provided, it will be applied to all sides. If two values are specified, they will be applied to horizontal and vertical padding.
r = d << report;
Show( tb << Get Padding );
tb << Border( 1 );
Wait( 1 );
tb << Padding( Left( 20 ), Top( 20 ), Right( 20 ), Bottom( 20 ) );
Get Page Setup
Syntax: obj << Get Page Setup
Description: Get page setup information for PDF
w = New Window( "Window", Text Box( "Page Setup Test" ) );
w << get page setup();
Get Picture
Syntax: obj << Get Picture( <Scale(factor)>, <Type("Bitmap" | "Scalable")>, <View("Picture" | "Screen" | "Print"), <Appearance("Default" | "Current")>, <SubRect(Left(number), Top(number), Right(number), Bottom(number))> )
Description: Captures db as an Image Object. The optional Scale argument will render the image at a scaled resolution. Scaling requires that the display box be stretchable. The Type argument determines whether the result will be a scalable vector image or a bitmap. By default a scalable image is returned, which is suitable for saving to vector formats like PDF. The View option changes the behavior of some boxes. The default option of "Picture" draws the report as it would when exporting to an image format, with scrolled areas fully shown. View mode of "Screen" draws the report as seen on-screen, and "Print" draws the report as it does when printing, without any of the page setup features. The SubRect option will capture a portion of the resulting image rather than a full image. The Appearance option can change from the "Default" output colors to the "Current" colors as seen on-screen. The View, SubRect, and Appearance options are only supported for Type "Bitmap".
Default
New Window( "Example", rbiv << Get Picture );
Scale
rbiv[FrameBox( 1 )] << Set Stretch( "Window", "Window" );
New Window( "Example", rbiv << Get Picture( Scale( 1.5 ) ) );
View and Appearance
    Y( :weight ),
    X( :height ),
    Fit Line( {Line Color( {212, 73, 88} )} ),
    Fit Polynomial( 3, {Line Color( {61, 174, 70} )} ),
    Kernel Smoother( 1, 1, 0.5, 0 )
    H List Box(
        rbiv << Get Picture( View( "Screen" ), Appearance( "Current" ) ),
        rbiv << Get Picture( View( "Print" ), Appearance( "Default" ) )
Get Project
Syntax: project = obj << Get Project()
Description: Returns the parent project of the window, or Empty() if it is not in a project.
JMP Version Added: 14
c = w << Get Project();
Show( c );
Get Properties
Syntax: obj << Get Properties
Description: Returns an associative array that contains the display box's properties and their values.
New Window( "Example", bb = Button Box( "Press Me", Print( "Pressed" ) ) );
bb << Get Properties;
Get Property
Syntax: obj << Get Property( "property" )
Description: Returns the current setting for the named property.
bb << Get Property( "Enabled" );
Get Property List
Syntax: obj << Get Property List
Description: Returns a list of properties the display box has.
bb << Get Property List;
Get RTF
Syntax: obj << Get RTF( <format> )
Description: Returns a string containing RTF source for the display box.
Example 1
a << Set Text( win << Get RTF );
Example 2
Save Text File( "$TEMP/Oneway.rtf", obj << Get RTF( "png" ) ); // Prefer <<Save RTF
Open( "$TEMP/Oneway.rtf" );
Get Row States
Syntax: rs = obj << Get Row States( <dt> )
Description: Returns a vector containing the row state for every row in the given data table or the current data table. The row states can come from the table, or from the filter context of the box.
Single table
New Window( "filter test",
    Data Filter Context Box(
        H List Box(
            dt << Data Filter(
                Local,
                Add Filter( columns( :height ), Where( :height >= 51 & :height <= 62 ) ),
                Mode( Select( 0 ), Show( 1 ), Include( 1 ) )
            V List Box(
                t = Text Box( "0 Rows Excluded" ),
                Distribution(
                    Continuous Distribution( Column( :weight ) ),
                    Nominal Distribution( Column( :age ) )
updatetext = Function( {},
    rs = t << Get Row States( dt );
    n = 0;
    For( ii = 1, ii <= N Rows( rs ), ii++,
        If( Excluded( As Row State( rs[ii] ) ),
            n
    t << Set Text( Char( n ) || " Rows Excluded" );
rsupdate = Function( {a},
    If( Is Matrix( a ),
        updatetext()
rsh = t << Make Row State Handler( dt, rsupdate );
updatetext();
Where subset
    dist = Distribution(
        Nominal Distribution( Column( :age ) ),
        Local Data Filter(
        Where( :sex == "F" )
subset = dist << Get Data Table();
    rs = Report( dist ) << Get Row States( subset );
    n = 0;
            n
    If( Is Matrix( a ),
        updatetext()
rsh = Report( dist ) << Make Row State Handler( subset, rsupdate );
updatetext();
Get Show Window
Syntax: obj << Get Show Window
Description: Returns the visibility of the window.
Wait( 1 );
w << Show Window( 0 );
Wait( 2 );
Print( w << Get Show Window() );
Get Size
Syntax: width,height = obj << Get Size
Description: Returns the size of the display box.
r = d << report;
Print( fb << Get Size );
Get Stretch
Syntax: x,y = obj << Get Stretch
Description: Returns the stretching flags for this display box in the horizontal and vertical directions.
JMP Version Added: 16
New Window( "Stretch",
    V List Box(
        H List Box( Text Edit Box( "String1" ), Text Edit Box( "String2" ) ),
        spacer = Spacer Box(
            Size( 20, 20 ),
            Color( "Light Red" ),
            <<Set Stretch( "Fill", "Off" )
spacer << Get Stretch();
Get Text
Syntax: obj << Get Text
Description: Returns a string containing the text of the display box.
a << Set Text( win << Get Text );
Get Text Color
Syntax: obj << Text Color( color );color = obj << Get Text Color
Description: Text will be drawn using the text color if it has been set. If the property has not been set, the box will inherit the text color of the containing box.
r = d << report;
Show( tb << Get Text Color );
Wait( 2 );
tb << Text Color( "Red" );
Get UI Only
Syntax: obj << UI Only( state=0|1 );state = obj << Get UI Only
Get Vertical Alignment
Syntax: obj << Vertical Alignment( "Default"|"Top"|"Center"|"Bottom" );"Default"|"Top"|"Center"|"Bottom" = obj << Get Vertical Alignment
Description: Vertical alignment controls the positioning of the box within a container if the box does not fill the entire space.
r = d << report;
lb << Set Horizontal( 1 );
lb = r[List Box( 7 )];
lb << Border( 1 );
Wait( 2 );
lb << Vertical Alignment( "Bottom" );
Get Visibility
Syntax: obj << Visibility( "Visible"|"Hidden"|"Collapse" );"Visible"|"Hidden"|"Collapse" = obj << Get Visibility
Description: Visibility determines whether a box is shown and whether it takes up space. The default value of "Visible" means that the object will be shown. A "Hidden" box is not shown but still takes up space, while a "Collapsed" box takes up no space in the layout.
r = d << report;
Show( tb << Get Visibility );
Wait( 1 );
tb << Visibility( "Collapse" );
Get Web Support
Syntax: obj << Get Web Support
Description: Return a number indicating the level of Interactive HTML support for the display object. 1 means some or all elements are supported. 0 means no support.
obj = Bivariate( Y( :Weight ), X( :Height ) );
s = obj << Get Web Support();
Show( s );
Get Width
Syntax: width = obj << Get Width
Description: Returns the width of the display box.
r = d << report;
fb << Get Width;
Get Window Icon
Syntax: obj << Get Window Icon
Description: Returns the window icon.
t = w << Get Window Icon;
Show( t );
Get Window Position
Syntax: obj << Get Window Position
Description: Returns the position of the window.
p = w << Get Window Position();
Show( p );
Get Window Size
Syntax: obj << Get Window Size
Description: Returns the size of the window.
s = w << Get Window Size();
Show( s );
Get Window Title
Syntax: obj << Get Window Title
Description: Returns the window title.
t = w << Get Window Title;
Show( t );
Get Window View
Syntax: obj << Get Window View
Description: Returns the current window view. Windows can be "Visible", "Invisible", or "Private".
Print( w << Get Window View() );
Get XML
Syntax: obj << Get XML( <English(0|1)>, <NoData(0|1)> )
Description: Retrieves the display tree formatted as XML. By default, strings are returned in the local language, and the XML includes data values within some boxes. Use the English option to return English strings where available. Use the NoData option to omit the data values within boxes, which can be very large for some display trees.
win = New Window( "test", a = Text Box( "my test" ) );
a << set text( win << get xml );
GetOffset
Syntax: x,y = obj << GetOffset
Description: Returns the offset of this display box relative to the parent box. You might need to use the <<parent message in a loop to accumulate several offsets.
New Window( "example",
    MouseBox(
        Graph Box(
            title( "title" ),
            Pen Size( 3 );
            Y Function( -3 + 100 / 2 * (1 + Sin( (2 * Pi() * (x + .3)) / 100 )), x );
        <<settrackenable( 1 ) // put the mouse box to work, watching "tracking"
        <<settrack( // events from the mouse (movement, with button up or down)
            Function( {this, pt}, // parameters: this is the mousebox, pt is mouse x,y
                {fb, offset, t, off, size}, // local variables
                // recalulate offset and size each time, the values can change
                fb = this[framebox( 1 )]; // the framebox in the graph
                offset = [0, 0]; // accumulator to sum up the offset between framebox and mousebox
                t = fb; // a temporary box that starts at the frame
                While( t != this, // and walks up to the mousebox
                    off = t << getOffset; // ask each box for its offset to the immediate parent
                    offset += Matrix( off ); // convert list answer to matrix so + will work
                    t = t << parent; // crawl up to the mousebox, one box at a time
                size = Matrix( fb << getSize ); // the frame knows its size
                If( // over the frame box
                    offset[1] < pt[1] < offset[1] + size[1] & offset[2] < pt[2] < offset[2]
                     + size[2]
                    fb << setbackgroundcolor( "red" ),
                    fb << setbackgroundcolor( "blue" )
r = d << report;
lb << Border( 1 );
Wait( 2 );
Inval
Syntax: obj << Inval
Description: Invalidate the displaybox. The window will update when either the <<UpdateWindow message is sent or the operating system has time for the update.
color = "green"; /* initial color in a variable */
New Window( "Inval example",
    Button Box( "red",
        color = "red";
        g1 << inval; /* tell the oval to redraw */
        g2 << inval; /* tell the rectangle to redraw */
        g1 << updateWindow; /* tell the window to update immediately */
        // this is a busy-wait to help demonstrate the various behaviors...
        x = Tick Seconds();
        While( Tick Seconds() - x < .5, 0 /* delay without wait(.5) */ );
    Button Box( "blue",
        color = "blue";
        g1 << inval; /* same comments */
        g2 << inval;
        g1 << updateWindow;
        x = Tick Seconds();
        While( Tick Seconds() - x < .5, 0 );
    g1 = Graph Box(/* the graph does NOT watch for the color variable to change
                      but will use the current value of color when it reshows */
        Fill Color( color );
        Oval( 10, 80, 70, 50, 1 );
    g2 = Graph Box(
        Rect( 10, 80, 70, 50, 1 );
Is Dirty
Syntax: obj << Is Dirty
Description: Gets the document's modified status. 1 means the document has been modified and will prompt for saving; 0 means the document is not modified.
ww = New Window( "Test", <<Script, "Open(\!"$SAMPLE_DATA\Big Class.jmp\!");" );
Show( ww << Is Dirty );
ww << Set Dirty( 0 );
Is Modal Dialog
Syntax: obj << Is Modal Dialog
Description: Returns true if the window is a modal dialog. Only useful when called from a window handler callback.
With Window Handler(
    New Window( "Modal Window", <<Modal ),
    Function( {win},
        Print( win << Is Modal Dialog() );
        win << close window();
Journal
Syntax: obj << Journal
Description: Makes a journal from the display box.
rbiv << journal;
Journal Window
Syntax: obj << Journal Window
Description: Opens a journal window of the window.
w = New Window( "Main Window", Text Box( "Main JMP Window" ) );
w << Journal Window;
Launch
Syntax: obj << Launch
Description: Evaluates the given argument in the context of the display box.
    ob1 = Outline Box( "treemap launcher" ),
    ob2 = Outline Box( "bivariate partial" ),
    ob3 = Outline Box( "bivariate launched" )
ob1 << launch( Treemap() );
ob2 << launch( Bivariate( Y( :height ) ) );
ob3 << launch( Bivariate( Y( :height ), X( :weight ) ) );
Make RowState Handler
Syntax: rs = obj << Make RowState Handler( <dt>, function(a) )
Description: Creates a row state handler for the given data table or the current data table. The function is called when the row states change in the filter context of the box. The argument of the function holds the rows numbers that have changed, or -1 if the row state filter has changed.
Single table
        H List Box(
            dt << Data Filter(
                Local,
            V List Box(
                Distribution(
    n = 0;
            n
    If( Is Matrix( a ),
        updatetext()
updatetext();
Where subset
        Local Data Filter(
    n = 0;
            n
    If( Is Matrix( a ),
        updatetext()
updatetext();
Margin
r = d << report;
tb << Border( 1 );
Wait( 2 );
Maximize Window
Syntax: obj << Maximize Window( <state=0|1> )
Description: Maximizes the window. Default argument is 1.
Wait( 1 );
w << Maximize Window( 1 );
Wait( 1 );
w << Maximize Window( 0 );
Minimize Window
Syntax: obj << Minimize Window( <state=0|1> )
Description: Minimizes the window. Default argument is 1.
Wait( 1 );
w << Minimize Window( 1 );
Wait( 1 );
w << Minimize Window( 0 );
Move Window
Syntax: obj << Move Window( x,y )
Description: Moves the window to the specified position.
Wait( 2 );
w << Move Window( 500, 500 );
Syntax: obj << Next
Description: Returns the display box after this display box.
next = rbiv << Next();
Print( next << Class Name() );
On Close
Syntax: obj << On Close( script )
Description: Sets a script or function to run upon closing the window. This script should return 1 to allow the close, or 0 to prevent the window from closing.
Close Function
w << On Close(
    Function( {this},
        // Modal dialogs return Button(1) if OK is pressed, Button(-1) if cancelled
            <<modal,
            V List Box(
                Text Box( "Press OK to allow " || (this << Get Window Title) || " to close" ),
        )["button"] == 1
Close Script
w << On Close(
        <<modal,
        V List Box(
    )["button"] == 1
Optimize Display
Syntax: obj << Optimize Display
Description: Sets a data table's column widths and window to an optimum size.
//This message applies to Data Table objects
dt << Optimize Display;
Pad Window
Syntax: obj << Pad Window( bool )
Description: Turns window padding on or off.
d = distribution( Column( :height ) );
r = d << report;
r << Pad Window( 0 );
Padding
r = d << report;
tb << Border( 1 );
Wait( 1 );
Page Break
Syntax: obj << Page Break
Description: Inserts a page break before the display box.
    ob = Outline Box( "Outline Box",
        V List Box(
            ob2 = Outline Box( "Outline Box 2",
                H List Box( Text Edit Box( "Top Left" ), Text Edit Box( "Top Right" ) )
            ob3 = Outline Box( "Outline Box",
                H List Box( Text Edit Box( "Bottom Left" ), Text Edit Box( "Bottom Right" ) )
ob3 << Page Break;
Parent
Syntax: obj << Parent
Description: Returns the parent of this display box.
Print( axisParent << Class Name() );
Prepend
Syntax: obj << Prepend( db2 )
Description: Add db2 to the display tree before db.
rbiv << prepend( Text Box( "=== above ===" ) );
Prev Sib
Syntax: obj << Prev Sib
Description: Returns the previous sibling of the display box.
axisbox = rbiv[axis box( 2 )];
axisSibling = axisbox << Prev Sib();
Print( axisSibling << Class Name() );
Syntax: obj << Print Window
Description: Prints the window.
w << Print Window;
Reshow
Syntax: obj << Reshow
Description: Invalidate the displaybox and update the window with the new content. See <<Inval and <<UpdateWindow messages if more control over timing of the update is required.
New Window( "Reshow example",
    Button Box( "red",
        color = "red";
        g << reshow/* tell the graph that something changed */;
    Button Box( "blue",
        color = "blue";
    g = Graph Box(/* the graph does NOT watch for the color variable to change
Save Capture
Syntax: obj << Save Capture( <"path">, <format>, <Add Sibling(n)> )
Description: Saves a screen capture of the display box at the specified path. If a path is not given, the Save As window appears.
rbiv << Save Capture( "$TEMP/jmp_example.png", "png" );
Save HTML
Syntax: obj << Save HTML( <pathname>, <format> )
Description: Saves HTML source and folder of graphics in format specified.
rbiv << Save HTML( "$TEMP/jmp_example.html" );
Save Interactive HTML
Syntax: obj << Save Interactive HTML( <pathname>, <Boolean> )
Description: Saves Interactive HTML with Data to a file. The Boolean argument represents the report being static.
rbiv << Save Interactive HTML( "$TEMP/jmp_example.html" );
Save Journal
Syntax: obj << Save Journal( <pathname> )
Description: Saves journal source for the display box.
rbiv << Save Journal( "$TEMP/jmp_example.jrn" );
Save MSWord
Syntax: obj << Save MSWord( <pathname>, <format> )
Description: Saves the display box as a Microsoft Word document. (Windows Only)
rbiv << Save MSWord( "$TEMP/jmp_example.doc" );
Save PDF
Syntax: obj << Save PDF( <pathname>, <Show Page Setup(0|1)>, <Portrait(0|1)> )
Description: Saves a PDF of the display box.
rbiv << Save PDF( "$TEMP/jmp_example.pdf" );
Save Picture
Syntax: obj << Save Picture( <pathname>, <format>, <Scale(factor)>, <Type("Bitmap" | "Scalable")>, <View("Picture" | "Screen" | "Print"), <Appearance("Default" | "Current")>, <SubRect(Left(number), Top(number), Right(number), Bottom(number))> )
Description: Saves a picture of the display box. Supported formats are EMF(Windows), PICT(Macintosh), JPEG or JPG, GIF, or PNG. The optional Scale argument will render the image at a scaled resolution. Scaling requires that the display box be stretchable. The Type argument determines whether the result will be a scalable vector image or a bitmap. By default a scalable image is returned, which is suitable for saving to vector formats like PDF. The View option changes the behavior of some boxes. The default option of "Picture" draws the report as it would when exporting to an image format, with scrolled areas fully shown. View mode of "Screen" draws the report as seen on-screen, and "Print" draws the report as it does when printing, without any of the page setup features. The SubRect option will capture a portion of the resulting image rather than a full image. The Appearance option can change from the "Default" output colors to the "Current" colors as seen on-screen. The View, SubRect, and Appearance options are only supported for Type "Bitmap".
Default
rbiv << Save Picture( "$TEMP/jmp_example.png", "png" );
Scale
rbiv << Save Picture( "$TEMP/jmp_example_scale.png", "png", Scale( 1.5 ) );
New Window( "scaled image", New Image( "$TEMP/jmp_example_scale.png" ) );
View and Appearance
    Y( :weight ),
    X( :height ),
    "$TEMP/jmp_example_screen.png",
    "png",
    View( "Screen" ),
    "$TEMP/jmp_example_print.png",
    "png",
    View( "Print" ),
    H List Box(
        New Image( "$TEMP/jmp_example_screen.png" ),
        New Image( "$TEMP/jmp_example_print.png" )
Save Presentation
Syntax: obj << Save Presentation( "filename.pptx", <Template("path\to\my_template.pptx")>, <Insert(Begin|End|#) | Replace(Begin|End|#) | Append>, <Outline Titles(None|Hide|TopLeft|TopRight|BottomLeft|BottomRight)>, <"EMF"|"PNG"|"JPG"|"Native"> )
Description: Saves the display box tables and graphs slides in a presentation. The presentation can be opened with Microsoft PowerPoint or other presentation software.
biv = bivariate( y( :weight ), x( :height ) );
rbiv << Save Presentation( "$TEMP/jmp_example.pptx" );
Open( "$TEMP/jmp_example.pptx" );
Save RTF
Syntax: obj << Save RTF( <pathname>, <format> )
Description: Saves RTF source with graphics in format specified.
rbiv << Save RTF( "$TEMP/jmp_example.rtf", "png" );
Save Text
Syntax: obj << Save Text( <pathname>, <format> )
Description: Saves a file containing the text of the display box.
a << save text( "$TEMP/jmp_example.txt" );
Save Window Report
Syntax: obj << Save Window Report( pathname, <embed data(0|1)> )
Description: Saves the current report window to a JMP report file (.jrp).
//This message can be sent to any display box object but will be applied to the report window
d << Save Window Report( "$DOCUMENTS/test.jrp", embed data( 1 ) );
Scroll Window
Syntax: obj << Scroll Window( DisplayBox | <Relative(<v> | <h>,<v>)> | <Absolute(<v> | <h>,<v>) )
Description: Adjust the window scrollbar to bring the given DisplayBox into view, or scroll a relative number of pixels, or scroll to an absolute pixel location. In place of a number of pixels the keywords "Start" or "End" can be used.
Absolute
Open( "$SAMPLE_DATA/Blood Pressure.jmp" );
fm = Fit Model(
    Y( :BP 8M, :BP 12M, :BP 6M, :BP 8W, :BP 12W, :BP 6W, :BP 8F, :BP 12F, :BP 6F ),
    Effects( :Subject, :Dose ),
    Personality( "Manova" ),
    Run
fm << setwindowsize( 600, 600 ); // shrink the window
fm << scroll window( Absolute( "End", "End" ) );
Wait( 1 );
fm << scroll window( Absolute( 0, 300 ) );
Wait( 1 );
Box
fm = Fit Model(
    Run
For( i = 1, i <= 5, i++, // repeatedly, bring each frame box into view for 1/2 second
    fm << scroll window( Report( fm )[framebox( 2 )] );
    Wait( .5 );
    fm << scroll window( Report( fm )[framebox( 3 )] );
    Wait( .5 );
    fm << scroll window( Report( fm )[framebox( 1 )] );
    Wait( .5 );
Relative
fm = Fit Model(
    Run
fm << scroll window( Relative( 300 ) );
Wait( 1 );
fm << scroll window( Relative( -50 ) );
Wait( 1 );
fm << scroll window( Relative( "Start" ) );
Wait( 1 );
Select
Syntax: obj << Select
Description: Selects this object for use by Edit menu commands.
New Window( "Example", ex = Button Box( "Press Me" ) );
ex << Select;
Set Content Size
Syntax: obj << Set Content Size( x,y )
Description: Sets the content size within the window.
    lb = List Box( {"a", "b", "c", "d"} ),
    Button Box( "Enable 2nd item",
        lb << enable item( 2, 1 );
        Show( lb << item enabled( 2 ) );
    Button Box( "Disable 2nd item",
        lb << enable item( 2, 0 );
Wait( 2 );
w << Set Content Size( 400, 300 );
Set Dirty
Syntax: obj << Set Dirty
Description: Sets the document's modified status. 0 will not prompt for saving; 1 will prompt.
Set Height
Syntax: obj << Set Height( width )
Description: Sets the height of the display box.
r = d << report;
fb << Set Height( 150 );
Set Main Window
Syntax: obj << Set Main Window
Description: Set the window to be the main window in JMP and sets the prior main window to be a normal window
w << Set Main Window;
Set Max Size
Syntax: obj << Set Max Size( width,height )
Description: Sets the maximum size of this display box for purposes of auto-stretching.
r = d << report;
fb << Set Max Size( 500, 500 );
fb << Get Max Size;
Set Min Size
Syntax: obj << Set Min Size( width,height )
Description: Sets the minimum size of this display box for purposes of auto-stretching.
r = d << report;
fb << Set Min Size( 30, 30 );
fb << Get Min Size;
Set Page Setup
Syntax: obj << Set Page Setup( <margins(left, top, right, bottom)>, <scale(s)>, <portrait(0|1)>, <paper size(p)>, <Table of Contents(always, never, default)> )
Description: Sets the page setup information that is used during printing or saving as pdf. A Table of Contents can optionally be generated from Outline Boxes.
w = New Window( "Window", Outline Box( "TOC", Text Box( "Page Setup Test" ) ) );
w << Set page setup(
    margins( 1, 1, 1, 1 ),
    scale( 1 ),
    portrait( 1 ),
    paper size( "Letter" ),
    Table of Contents( "always" )
w << Save pdf( "$DOCUMENTS\test.pdf" );
Set Print Footers
Syntax: obj << Set Print Footers( left footer, center footer, right header )
Description: Sets the left, center, and right footers for printed output
w = New Window( "Window", Text Box( "Footer Test" ) );
w << Set Print Footers(
    "Today is: &d;"/*left*/, "&wt;"/*center*/,
    "Page &pn; of &pc;"/*right*/
w << Print Window;
Set Print Headers
Syntax: obj << Set Print Headers( left header, center header, right header )
Description: Sets the left, center, and right headers for printed output
w = New Window( "Window", Text Box( "Header Test" ) );
w << Set Print Headers(
w << Print Window;
Set Property
Syntax: obj << Set Property( "property", value )
Description: Sets the value for the named property for the display box.
bb << Set Property( "Enabled", 0 );
Set Report Title
Syntax: obj << Set Report Title( "string" )
Description: Changes the report title.
rbiv << Set Report Title( "New Title" );
Set Stretch
Syntax: obj << Set Stretch( x,y )
Description: Sets the horizontal and vertical stretching behavior of the box. Boxes that stretch with Window will resize as the window or splitter size changes. Boxes that stretch to Fill will stretch to fill available space in their container. Boxes with stretching turned Off generally will not stretch. Most boxes default to Neutral, which means that they will determine their behavior based on their child boxes.
Stretch to Fill
    V List Box(
        Spacer Box( Size( 20, 20 ), Color( "Light Red" ), <<Set Stretch( "Fill", "Off" ) )
Stretch with Window
    H List Box(
        tv = Text Box( "V+V", <<rotate text( left ) ),
        V List Box(
            Text Box( "resize the containing window" ),
            th = Text Box( "H+H" ),
            ts = Spacer Box( <<Size( 10, 30 ), <<Color( "blue" ) )
tv << Vertical Alignment( "Center" );
th << Horizontal Alignment( "Center" );
th << Set Stretch( "Window", "Off" );
ts << Set Min Size( 5, 20 );
ts << Set Max Size( 100000, 100 );
ts << Set Stretch( "Window", "Window" );
Set Summary Behavior
Syntax: obj << Set Summary Behavior( "Default"|"Visible"|"Collapse" )
Description: Sets the behavior of the box when a report is viewed in Summary mode.
d << Report View( "Summary" );
r = d << Report;
tb << Set Summary Behavior( "Visible" );
Set Width
Syntax: obj << Set Width( width )
Description: Sets the width of the display box.
r = d << report;
fb << Set Width( 400 );
Set Window Icon
Syntax: obj << Set Window Icon( icon name )
Description: Sets the window icon.
w = New Window( "Example", ex = Button Box( "New Analysis" ) );
w << Set Window Icon( "Scatter3D" );
Set Window Size
Syntax: obj << Set Window Size( x,y )
Description: Sets the size of the window.
w << Set Window Size( 800, 1200 );
Set Window Title
Syntax: obj << Set Window Title( "string" )
Description: Changes the window title.
rbiv << Set Window Title( "New Title" );
Show Properties
Syntax: obj << Show Properties
Description: Displays a property editor for display boxes
rbiv << Show Properties();
Show Tree Structure
Syntax: obj << Show Tree Structure
Description: Displays a hierarchical tree structure of the display box and its related nodes.
rbiv << Show Tree Structure();
Show Window
Syntax: obj << Show Window( state=0|1 )
Description: Shows or hides the window. This is useful for hiding windows temporarily. On by default.
Wait( 1 );
Wait( 2 );
w << Show Window( 1 );
Sib
Syntax: obj << Sib
Description: Returns the sibling of the display box.
axisSibling = axisbox << sib();
Sib Append
Syntax: obj << Sib Append( Display box, Horizontal|Vertical )
Description: Adds a display box immediately after this display box.
r = d << report;
fb = r()[framebox( 1 )];
fb << sib append(
    Text Box( "============ after ==============", Rotate Text( "Right" ) ),
    "Horizontal"
fb << sib append( Text Box( "=== below ===" ), "Vertical" );
Sib Prepend
Syntax: obj << Sib Prepend( Display box, Horizontal|Vertical )
Description: Adds a display box immediately before this display box.
r = d << report;
fb << sib prepend(
    Text Box( "    ============ before ==============", Rotate Text( "Right" ) ),
    "Horizontal"
fb << sib prepend( Text Box( "=== above ===" ), "Vertical" );
Size Window
Syntax: obj << Size Window( x,y )
w << Size Window( 500, 500 );
Text Color
r = d << report;
Wait( 2 );
Top Parent
Syntax: obj << Top Parent
Description: Returns the root parent of this display box.
rootParent = rbiv << Top Parent();
Print( rootParent << Class Name() );
UI Only
Update Window
Syntax: obj << Update Window
Description: Update the window holding the displaybox if there are invalidated regions. The <<Inval message creates invalidated regions.
New Window( "UpdateWindow example",
    Button Box( "red",
        color = "red";
        // try commenting out each of the 4 lines that follow, run the script,
        // click the buttons, and resize the windows (for example) to force a
        // redraw.  All 4 lines are important, though the last two may be
        // slightly different on Windows and Mac OSs.
        g1 << updateWindow; /* tell the oval window to update immediately */
        g2 << updateWindow; /* tell the rect window to update immediately */
        x = Tick Seconds();
    Button Box( "blue",
        color = "blue";
        g2 << inval;
        g1 << updateWindow;
        g2 << updateWindow;
        x = Tick Seconds();
New Window( "oval",
New Window( "rect",
    g2 = Graph Box(
Vertical Alignment
r = d << report;
lb << Border( 1 );
Wait( 2 );
Visibility
r = d << report;
Wait( 1 );
Window Class Name
Syntax: obj << Window Class Name
Description: Returns the name of the window class for the display box.
Show( biv << Window Class Name() );
Show( rbiv << Window Class Name() );
XPath
Syntax: obj << XPath( XPath expression, <English(0|1)>, <NoData(0|1)> )
Description: Applies an XPath expression to the XML representation of the display tree and returns the results. By default, strings are returned in the local language, and the XML includes data values within some boxes. Use the English option to return English strings where available. Use the NoData option to omit the data values within boxes, which is useful for performance when your query is based only on box attributes.
Attributes
(Report( biv ) << xpath( "//OutlineBox[@isOpen='false']" )) << Close( 0 );
Box type
(Report( biv ) << xpath( "//TextEditBox" )) << Text Color( "Green" );
Child box
(Report( biv ) << xpath( "//OutlineBox[text()='Summary of Fit']/TableBox" )) <<
Make Into Data Table;
Data
(Report( biv ) << xpath( "//NumberColBoxItem[text()='40']/parent::*" )) <<
Display Seg
(Report( biv ) << xpath( "//MarkerSeg" )) << Set Marker( "Square" );
Text
(Report( biv ) << xpath( "//OutlineBox[text()='Parameter Estimates']" )) << Close;
Zoom Window
Syntax: obj << Zoom Window
Description: Resizes the window to be large enough to show all of its contents.
w << Set Window Size( 80, 120 );
Wait( 2 );
w << Zoom Window;
